Dynamic Linking from Premiere- single frame overlapping bug
jim bachalo
on Oct 20, 2013 at 9:02:37 pm
There is an annoying bug with dynamic linking whereby instead of a clean cut between shots, you end up with a single frame that overlaps with a dissolve.
The end result being a single frame that ends up darker in the final render.
The only solution I've found is to manually option-shift click the ends of the shots on the layers to re align them.
Does anyone know of a better solution?
Local is the new global
Todd Kopriva
Re: Dynamic Linking from Premiere- single frame overlapping bug
on Oct 21, 2013 at 6:40:01 pm
Please report bugs here:
http://adobe.ly/ReportBug
After Effects team blog
