series of quick camera shakes with abberations
JonZ MarZ
on Oct 17, 2013 at 7:06:35 pm
I'm mind boggled about doing that seem rather simple.
I am trying to achieve a series of transitions that involve camera shakes with camera abberations effect. It take me a while to make a single one and I am barely satisfied with.
What I do is to separate the logos in 3 layers different in additive blend mode and apply a wiggle on each of them, but it doesn't look professional and it take a while to tweak, I need to do this about 10 times for each logos. Heck. I won't bother getting a pluggin that can do it.
Wiggling is the hardest part because I am doing it manually. Maybe I can make it more simple with a slider control effect expression, but I never used it yet.
A concrete example is this YT Slideshow, which is about the same thing I try to achieve:
John Cuevas
Re: series of quick camera shakes with abberations
on Oct 17, 2013 at 8:25:44 pm
I don't see your example, but check out this thread from last year. I even uploaded a example file. See if that gives you a start. Camera Twitch/Shake Colour transition
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
mathew fuller
on Oct 17, 2013 at 9:05:46 pm
You could try this.
Use this expression as an interactive, keyframeable Wiggler. Apply it to the property of the layer you wish to wiggle.
wigfreq = 3; //wiggle frequency
wigamt = 30; //wiggle amount
wigdetail = 3; //detail of noise
wiggle(wigfreq, wigamt, wigdetail)
~ Mat
My Work:
http://www.morecompletefx.com
Kevin Camp
on Oct 17, 2013 at 11:26:28 pm
to build off mathew's expression, this one will 'bump' at every comp layer marker, so you can trigger the wiggle by adding comp markers.
freq = 10;
amount = 50;
detail = 5;
decay = 10; //how fast it slows down
n = 0;
if (thisComp.marker.numKeys > 0){
n = thisComp.marker.nearestKey(time).index;
if (thisComp.marker.key(n).time > time){
n--;
if (n == 0){
value;
}else{
t = time - thisComp.marker.key(n).time;
a = amount/Math.exp(decay*t);
wiggle(freq,a,detail);
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
John Cuevas
on Oct 18, 2013 at 12:19:11 am
I'll be saving this one into my cool expressions doc...thanks Kevin.
Thinkck.com
Cassius Marques
on Oct 18, 2013 at 2:14:00 pm
Have you seen VideoCopilot's plugin Twitch? Because it seems that example used just it.
JonZ MarZ
on Oct 21, 2013 at 9:03:42 pm
thanks, indeed Twitch is about the answer I looked for, so I bought it :)
I appreciated the scripts bits tho, could use if for other purposes.
