Script for turning layers to guide layers directly from the project panel
David Cabestany
on Oct 16, 2013 at 7:48:25 pm
I have this piece of footage that I'm using 60 times across many compositions. For my final render I need to turn each layer where it;s used into a guide layer, does anyone know of a script that will let me do that by selecting the footage in the project panel instead of having to go comp by comp?
Thanks.
Walter Soyka
Re: Script for turning layers to guide layers directly from the project panel
on Oct 16, 2013 at 8:20:50 pm
I don't know of a script off-hand, but I'd just cheat. Maybe create a totally transparent PNG or PSD file, and then use the replace footage command? Don't forget to "Save As" or "Save Incremental" before proceeding...
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Roland R. Kahlenberg
on Oct 17, 2013 at 2:38:50 am
Excellent solution Walter. The only thing I'd do different is to use an empty Comp instead of the PSD/PNG.
Cheers
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
David Cabestany
on Oct 17, 2013 at 3:07:33 pm
Thanks guys, both solutions work great as final steps, but knowing the clients, I still need to go back and forth and tweak the animations using the original layer as reference, so I guess I will have to re-replace it again each time, it still beats doing it manually, nonetheless.
Thanks for the idea, it's a good one.
Walter Soyka
on Oct 17, 2013 at 3:13:37 pm
[David Cabestany] ", I still need to go back and forth and tweak the animations using the original layer as reference, so I guess I will have to re-replace it again each time, it still beats doing it manually, nonetheless."
You could use a transparent image as proxy so you could toggle it on or off, or like Roland suggested, you could right-click the footage item in the project panel, and choose "Replace with Precomp." Then you can open up that new precomp and enable/disable visibility of the footage layer inside to globally affect all instances.
Walter Soyka
David Cabestany
on Oct 17, 2013 at 3:18:06 pm
I think Roland's solution works better, having a proxy is good only if that's the only one on your project, if you have more then you have to turn them off for final render, as far as I know you can't leave some proxies on and some off in one project.
But again, this was very helpful, I really appreciate that you guys took the time to look into it.
Best,
D.
Walter Soyka
on Oct 17, 2013 at 3:40:41 pm
[David Cabestany] "I think Roland's solution works better"
I think so, too.
[David Cabestany] "having a proxy is good only if that's the only one on your project, if you have more then you have to turn them off for final render, as far as I know you can't leave some proxies on and some off in one project."
In the render queue, open Render Settings and set Proxy Use to "Current Settings."
Walter Soyka
