matte controls query
chris brett
on Oct 14, 2013 at 7:54:14 pm
Hi -
-- probably a daft query but the matte controls ( refine / choker ) seem to have stopped working ..
... presumably you apply the effect to the matte layer not the 'fill' ... ( ? ) .....
..... anyone got any ideas please ? ?
----------------------- chris
Cassius Marques
Re: matte controls query
on Oct 14, 2013 at 7:59:38 pm
Is it a luma matte? or a simple alpha?
chris brett
on Oct 14, 2013 at 8:08:07 pm
Hi Cassius
----------------- luma matte - not sure if the same with alpha --
----- what do you reckon ?
--------------------------------------chris ----
Cassius Marques
on Oct 14, 2013 at 8:27:00 pm
If you have a luma, you have to remember that you may be choking the edges that are black(or white if inverted luma matte) and that may not make a diference to the actual white matte colour.
On that case you have to precompose to be able to choke the alpha.
chris brett
on Oct 14, 2013 at 9:40:20 pm
--- sounds promising ......
------will give it a go tomorrow -----cheers -----chris
Dave LaRonde
on Oct 15, 2013 at 6:19:13 pm
Ah, you can't choke an opaque B&W image being used as a luma matte. There's no transparency in it, and so there is no choking done to it.
Dave LaRonde
Promotion Producer
Walter Soyka
on Oct 16, 2013 at 1:23:45 pm
If you have Sapphire, you can use S_MatteOps on luma mattes directly.
If you wish to choke a luma matte with Ae's built-in tools, you can use the Set Matte effect on the luma matte layer, setting it to use Luminance. This will generate alpha that can be manipulated with the Matte Choker.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
chris brett
on Oct 16, 2013 at 3:37:15 pm
Hi Walter, Dave and Cassius ----
------ many thanks to you all for your inight and advice --- much appreciated ------
All the best
Chris Brett
