Particular presets with 3D camera
Malcolm DeSoto
on Oct 13, 2013 at 7:20:21 pm
using Trapcode Particular, specifically, the two snow presets.
For some reason, every other preset EXCEPT for the two snow presets show up in the comp with a 3D camera.
Any idea why this is? I've been combing through the preset setting but can't find what it might be.
Again, if I turn off the camera visibility, the snow field will appear. Turn it on, and it disappears.
Erik Waluska
Re: Particular presets with 3D camera
on Oct 13, 2013 at 10:36:27 pm
Your 3D camera is probably not in its default position so it may be past the snowflake field so you just can't see the flakes. Try resetting the camera's position and point of interest to default (right-click>reset) and/or scrubbing the Z position back until you can see the flakes. If that doesn't work turn that camera off and add a new camera choosing one of the default presets (35mm, 28mm, etc.) and see if you can see the flakes then.
I have a snow and rain preset on my site that you may find useful as well.
Erik Waluska
© 2018 All Rights Reserved
