How to import every 20th frame
Justin Mettam
on Oct 11, 2013 at 4:06:22 am
I generated my image sequence out of Maya and rendered every 20th frame. How can I bring this sequence into AE so it reads frame 1 for 19frames then displays frame 20 for 19 frames etc. Or alternately bring in a sequence and but them all up against each other, for example frame 1,21,41,61 etc all together to be a 16frame sequence.
Currently AE puts color bars between fame 1 and 21 and 41 etc.
Thank you in advance.
Justin Mettam
Re: How to import every 20th frame
on Oct 11, 2013 at 4:13:23 am
Well I just discovered setting my comp to 1frame per second will kind of do the job, but it still puts color bars between each shot. frame 1 looks good frame 2 is color bars frame 3 looks good frame 4 is color bars etc.
Any other solutions ?
Erik Waluska
on Oct 11, 2013 at 8:00:03 pm
I would suggest precomping the image sequence and putting that into another comp and time remap it to stretch it out.
Erik Waluska
EAWmedia
Matthew Woods
on Oct 18, 2013 at 8:35:38 pm
Try checking "Force alphabetical order" when importing your image sequence. That should ignore the missing frames and treat it as a 16 frame image sequence.
Need a quick break from motion graphics?
Try my game Constellation at:
http://www.paperdragongames.com
