Items disappearing in comp when 3D and CR is turned on
Matt Michalko
on Oct 8, 2013 at 3:53:07 pm
Hi Everyone!
I have the following issue:
I have recently been working on a very simple corporate project that involves basic text/shape animations. The client sent us the slides all designed in AI and I imported them as compositions. So, each slide in the video is a comp. Everything obviously has continuously rasterize on because they are vector graphics. But, I wanted to make some of the text move in 3d space, so I did so, and all looks fine within the comp BUT when I go back to my main comp, everything shows up until it hits the part where the 3D layers are, then everything vanishes, which is weird because like I said, when I dig into the actual comp, everything is there and actually moving fine. If I uncheck the CR box or the 3D box it fixes the issue, the only problem is I cant leave the CR box unchecked because everything looks crappy and if I leave the 3D off..well..then I cant do what I want.
Any thoughts?
chris brett
Re: Items disappearing in comp when 3D and CR is turned on
on Oct 8, 2013 at 7:38:52 pm
Hi Matt
----------------- I cant exactly tell you how to fix it but I can tell you what it ( almost certainly )is and you can work it out from there I expect.....
I reckon its something to do with the elements not being precomped -- I know they are imported as comps but if you precomp the comp to 'flatten' it then try all the options with 3D and CR I think you will find one of them will work...
........ I reckon precomp the imported comp then check 3D and CR on BOTH the contents and the new comp itself....
------------------- all the best -----chris brett ---
Matt Michalko
on Oct 8, 2013 at 9:03:52 pm
Thanks Chris! A true hero! :P
Have a great evening!
Matt Michalko
on Oct 9, 2013 at 4:20:53 pm
Hmm... actually.. it seems that that didn't fix the issue. Any other ideas?
Roland R. Kahlenberg
on Oct 8, 2013 at 9:17:40 pm
It sounds like your CR nested comps are 2D in their lower level comps.
Ensure that the AI files/layers are also 3D in their respective precomps.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
