Editing keyframes after I've added an expression selector?
Sean Sweeney
on Oct 4, 2013 at 4:22:39 pm
I was unable to find anything while searching this, so here's my quick question:
After animating the range selector for a text animation, I wanted to add a simple bounce expression. So from what I've learned, I need to add the expression selector, and then delete the range selector. works great! But now what if I need to edit my keyframes? is there an easy way to do this or possibly add the expression without deleting my keyframes. Thanks!!
Roland R. Kahlenberg
Re: Editing keyframes after I've added an expression selector?
on Oct 7, 2013 at 12:56:19 am
Which property(s) are the keyframes on? How many keyframes are there in total. On which keyframes would you like to have the bounce in effect?
Cheers
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Sean Sweeney
on Oct 7, 2013 at 1:45:21 am
- It is typically position, scale, or rotation.
- there are usually only 2 keyframes for the text amination property, the Start and End.
on Oct 7, 2013 at 3:26:44 am
I'm still unclear what you want to do. If you want both the 'normal' Range Selector and the Expression Selector to work together then it's quite likely that the ideal solution is something closer to using 2 (or more) normal Range Selectors.
Anyway, you can use both the Expression and Range Selectors by setting the normal Range Selector's Mode (within the Advanced section) to either Subtract or Intersect.
HTH
RoRK
