stroke start/end size on a path
Ruud van Gerven
on Oct 2, 2013 at 2:33:49 pm
Hello Everyone,
I've created an animated stroke that moves along the path of a shapelayer. I've managed to do this by creating a shape layer and draw a shape with the pentool. Then i've went to the options of the shapelayer and added > trim path. This created a nice stroke that animates nicely along the path of my shape. It's possible to change the width of the stroke in general, but is it also possible to change the width of the start and end? See this image -->>>
Grtz Ruud
John Cuevas
Re: stroke start/end size on a path
on Oct 2, 2013 at 4:03:28 pm
You can with Trapcode 3D stroke. Not sure if you can taper the ends of a shape stroke.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ruud van Gerven
on Oct 3, 2013 at 7:11:44 am
Thanks John!
