Clone Stamp tool
Brendan McNamara
Clone Stamp tool
on Oct 1, 2013 at 5:26:40 pm
I'm trying to remove objects from the background with the clone stamp tool in after effects cs6. I'm trying to do it with the single frame method because it's only a few frames I need to touch up and don't need to do it throughout the whole duration of the clip. But every time to try to apply it to a new frame it cancels out the touch up in the previous frame. In the timeline it says clone 1 so I assume to do what I need to do is to add more clones in the timeline, but how do I do this?
mathew fuller
Re: Clone Stamp tool
on Oct 1, 2013 at 6:27:23 pm
In the Paint window your duration needs to be set to "single frame".
My Work:
http://www.morecompletefx.com
Brendan McNamara
on Oct 1, 2013 at 7:02:26 pm
I know that, but every time I try to do that it only applies it to that frame and cancels out the touch up I did to the previous frame
mathew fuller
on Oct 1, 2013 at 8:32:57 pm
Double click your footage so it opens in layer view rather than within the comp and paint away, should work. If not, review the adobe documentation on the clone tool and see what you're missing.
My Work:
