How to export a 3d tracked camera from AE to 3ds Max ?
Luiz Mihich
on Sep 25, 2013 at 11:05:53 pm
I know you can easily export a 3d camera tracked from a shot to Cinema 4d , but I
can't believe the excelent camera 3d track
in AE cc doen't export camera data in other formats, I use 3ds max 2014,for instance.
I am aware there's a script AE 3d , didn't work for me,version is obsolete, any suggestion ?
mathew fuller
Re: How to export a 3d tracked camera from AE to 3ds Max ?
on Sep 26, 2013 at 3:56:40 am
I use max with After FX all day every day. I cannot live without this plugin. You can send cameras, lights, and image planes back and forth... AE to MAX or MAX to AE.
http://boomerlabs.com/cart/product.php?productid=8&cat=3&page=1
You're welcome,
Mat
My Work:
http://www.morecompletefx.com
Luiz Mihich
on Sep 26, 2013 at 3:58:46 pm
Hi Mathew, Thank you for your reply !
I knew the plugin, but had the wrong idea about it, Does this plugin export a trackcamera created in After effects not
in Max ? because I am not interested to use
a camera created in Max but, instead ,take advantage of the tracking data obtained from a tracked shot in AE.
I really need to be sure ,as the plugin is not cheap, and I am still intrigued about Why this is not part of AE exporting capabilities!
