Snapping to whole frames
Ed Asined
on Sep 23, 2013 at 11:05:11 pm
Hello folks,
I could use a little advice:
I spent the last week creating an animated title sequence purely in AE at a standard 29.97fps and then right as I was finishing, the client told me that it was going to be shown in the UK and needed to be 25fps.
I know... I should have asked before starting. Seems like I never learn.
As there was no actual footage in the sequence I didn't think it would be a big deal to convert the project from 29.97 down to 25 - but now all of my text layers are not snapping to whole frames. They seem to lie half-way between frames. To fix this I'm having to go in and manually adjust every single layer... and there are a LOT of layers.
Does anyone know if there is a better way of doing this?
Was there something I should have done when converting - other than just going into the project settings and changing the frame rate?
Thanks in advance!
Todd Kopriva
Re: Snapping to whole frames
on Sep 24, 2013 at 2:49:56 am
Create a 25fps composition. Nest your 29.97fps composition in it. Render and export the 25fps composition. That's it.
After Effects team blog
© 2018 All Rights Reserved
