Hoping to reduce jittery text rendered from AE
Mike Tosetto
on Sep 20, 2013 at 12:35:56 am
Hey guys
I'm working on quite a simple video with lots of vertical lines moving horizontally across the screen revealing text.
I'm finding that I'm getting quite a bit of jitter/flicker, especially on the text when I render the footage.
I'm rendering to a lossless codec - Apple ProRes 422 HQ
The frame rate is 25 fps.
I don't want to add any motion blur as it's not in line with the brand but I'd like the lines and text to be as smooth as possible.
I did notice that when I increase the frame rate, the flicker seems to reduce, but am I able to upload a video with a frame rate of 100fps to Vimeo?
Here's a link to an 8MB sample of the video:
https://www.dropbox.com/s/0phyw3tnnjqtr4i/jitterExampleLo.zip
Any thoughts or suggestions would be much appreciated.
Cheers
Mike
miketosetto dot com
Roland R. Kahlenberg
Re: Hoping to reduce jittery text rendered from AE
on Sep 20, 2013 at 2:11:20 am
It's too troublesome to take a look at your video - I suggest uploading it to the COW and then provide the link in your posts.
To remove the jitters, try lowering the opacity and if that doesn't work, look at trying different speeds for your movement.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Dave LaRonde
on Sep 20, 2013 at 10:02:39 pm
Yipes! It's all vertical lines with horizontal motion!
You're experiencing the phenomenon known as judder, and it's most apparent at lower frame rates. Unfortunately, your frame rate is about as low as it can get.
Your options are to 1) change the speed of the horizontal motion or 2) change the speed of the horizontal motion. Adding motion blur to those vertical lines might help, too.
Dave LaRonde
Former Sr. Promotion Producer
Nathan Howe
on Sep 23, 2013 at 7:27:52 pm
Rather than adapting to multiples of frame rate, as animated motion is sometimes an arbitrary numerical value, I'll almost always use some type of motion blur, but it depends on the project. I have done it both ways though...
Todd Kopriva
on Sep 21, 2013 at 4:54:28 pm
See this page for tips on avoiding judder:
http://kb2.adobe.com/community/publishing/908/cpsid_90843.html
After Effects team blog
