After Effects Error - invalid ascend count '0'
Chris Morgan
on Sep 19, 2013 at 2:01:49 pm
I have had an issue with re linking a file into After Effects CC, I can re-import and replace the file in each comp manually but normally I simply reload the file that has been moved from its original location and it automatically updates the links.
The error displays when trying to reconnect an mp4 video with the correct file name etc, it is the same file nothing has changed After Effects simply won't re link it, instead it displays the error 'invalid ascend count '0''
Any takers?
Cheers in advance !
© 2018 All Rights Reserved
