Motion Tracking Question
Matt DeLoach
on Sep 18, 2013 at 2:47:00 pm
Hey Everyone,
Instead of recreating a similar animation in Cinema 4D or the like, I was wondering if anyone had a fairly simple solution to adding textures/icons to an existing animation I found on vimeo...
What would you guys recommend the simplest solution would be to adding texture "tiles" to each face of these cubes? I looked into trying the 3D camera tracker in AE, but it simply doesn't track the motion well enough or returns "analysis solve failed." after analysis.
I'm fully aware that I could add a tile to each cube face manually and keyframe everything with a camera or null object, but I'm wondering if anyone is aware of something far less tedious. Even paying for a plugin is an option if you happen to know of something that exists. I currently have both AE CS6 and CC installed.
Thanks in advance,
Matt
Roland R. Kahlenberg
Re: Motion Tracking Question
on Sep 23, 2013 at 9:02:56 am
It's an AE template. WHy not just purchase the template and be done with it?
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
