1080 50i Graphic (assistance required)
Brandon Adam
on Sep 15, 2013 at 2:27:12 pm
I have absolutely no idea on how to go about making a graphic at 1080i 50. Some,say go into after effects, set the render frame-rate to 25 "upper fields. When on final output, it does not look smooth enough via a UltraStudio Express to a TV monitor set to 1080i. We use PAL, so all my clips are at 25fps. I just need the graphics to playback smoothly.
Does anyone have a sample graphic for AE that relates to this setting (1080i 50)?
Thank you in advanced.
Tudor "Ted" Jelescu
Re: 1080 50i Graphic (assistance required)
on Sep 15, 2013 at 9:29:06 pm
Make sure you set the field order right- for 1080 50i it should be upper field first.
Here's a good chart for field order:
Tudor "Ted" Jelescu
Senior VFX Artist
© 2018 All Rights Reserved
