25fps to 50fps
John Mark
25fps to 50fps
on Sep 7, 2013 at 6:35:59 am
Will converting 25fps footage (from youtube) to 50fps, be okay? Or will create bad motion in the clips?
A News Graphic Lover
Erik Lindahl
Re: 25fps to 50fps
on Sep 7, 2013 at 12:58:32 pm
It really depends on the clip.
Dave LaRonde
Re: 25fps to 50fps
on Sep 7, 2013 at 6:31:22 pm
Sure, you can torn 25 fps into 50 fps, but if you expect to see a difference, you won't. When you step through the rendered footage frame by frame you'll notice that each frame is repeated. It's just the same as if you left it at 25.
Now, to get 50 different frames each second you can check out AE's Timewarp or you can use a plugin like Twixtor.
But if you simply put 25fps footage in a 50 fps comp, don't expect a miracle to happen.
Dave LaRonde
Former Sr. Promotion Producer
John Mark
Re: 25fps to 50fps
on Sep 8, 2013 at 1:48:30 am
Thanks Dave.
I ended up converting the clip to 50fps, works great.
