reverse speed issue
Robert Karli
reverse speed issue
on Sep 6, 2013 at 11:37:03 am
I have HDV upper fields footage. Edit to reverse speed and 50% of original speed. After rendering the footage is shaking like when export upper fields to lower fields. I tried interpret footage, reverse field dominance, flicker removal etc. If I use reverse speed OR slow speed works fine, but if I use both then not working.
© 2018 All Rights Reserved
