motion blur query
chris brett
motion blur query
on Sep 6, 2013 at 10:19:01 am
Hi
--- when I use motion blur there is no ramping of the effect - ie the blur does not fade gradually away and appears rather like a soft transparent block following the object.
Anyone got any ideas on how to make this taper away nicely please ?
Chris Brett
Dave LaRonde
Re: motion blur query
on Sep 6, 2013 at 3:03:50 pm
How quickly or slowly are you ramping the motion up & down? The speed of that ramping should be reflected in the amount of motion blur.
Dave LaRonde
Former Sr. Promotion Producer
chris brett
on Sep 6, 2013 at 4:05:03 pm
Hi Dave - thanks for the speedy reply ...
................. get motion blur ok which is proportional to speed but its all the same weight -- ie the pixels ( in the blur ) furthest from the object are the same density as those nearest ( I think ) .....
............. perhaps I need to take a closer look at it -- in the meantime please what is you favourite setting for motion blur and Ill start with that ...
All the best
Chris Brett
Cassius Marques
on Sep 6, 2013 at 6:06:49 pm
go to your composition settings and check for how much samples are set for motion blur in the advanced tab... default is 16 and 128.
chris brett
on Sep 7, 2013 at 12:04:59 pm
thanks Cassius --much appreciated -
- I reckon this is probably the answer though cant see how I managed to miss it !
........ all the best
Chris
