Creating Spherical world over ocean with Element 3D
John Orchard
on Sep 5, 2013 at 5:51:01 pm
Hi All!
I'm using an equirectangular sky image to texture an environment in E3D... the sky part works brilliantly, but I need an open ocean on the lower half. I've searched fairly extensively and can't seem to find something that works. Any suggestions, as it needs to be photorealistic. Thanks!
John
mathew fuller
Re: Creating Spherical world over ocean with Element 3D
on Sep 5, 2013 at 6:50:09 pm
Maybe try just using a regular spherical map with ocean and sky, using the horizon plugin from trapcode/red giant.
My Work:
http://www.morecompletefx.com
Tudor "Ted" Jelescu
on Sep 5, 2013 at 8:23:01 pm
Depending on your moves and how much you see, there's a couple of options out there.
Psunami is the ocean generator for AE that can allow for pretty realistic ocean simulation.
http://www.redgiant.com/products/all/psunami/
Then there's the Aqua Pack for FreeForm Pro, a series of preset projects (by yours truly) that use FF Pro to simulate water:
http://www.mettle.com/aqua-pack/
http://library.creativecow.net/jelescu_tudor/FreeForm-Pro_Aqua-Pack_1/1
http://library.creativecow.net/jelescu_tudor/FreeForm-Pro_Aqua-Pack_2/1
http://library.creativecow.net/jelescu_tudor/FreeForm-Pro_Aqua-Pack_3/1
Tudor "Ted" Jelescu
Senior VFX Artist
