Batch - Save Frame As
Ryan John
on Sep 2, 2013 at 5:11:44 pm
Is there a way to batch render "Save Frame As"?
Every clip I produce I need a thumbnail like image to go with it. Usually I just hit "Save Frame As" before rendering.
In this instance I need to do this for several hundred clips. I know I can drag and drop all the comps to the render queue to batch produce the clips, now I need to find a way to batch render the thumbnails too?
Erik Waluska
Re: Batch - Save Frame As
on Sep 2, 2013 at 7:47:47 pm
There's a script that will render still frames at every marker in the timeline - that might be your best bet,
Render Frame at Markers script
Also, in case you don't already know, the shortcut for "save frame as" is ctrl/cmd + shift + s.
You can set the default file type in Edit>Templates>Output Module>Frame Default.
Erik Waluska
EAWmedia
Jared Rowe
on Feb 14, 2016 at 6:46:09 am
Hey Ryan what did you end up learning here? I am in the same boat now and see that you dealt with this 2 years ago. What was your solution to batch the thumbnails?
