Filling the Screen
zoe griffiths
Filling the Screen
on Sep 1, 2013 at 3:36:25 pm
Hi all,
I have a question I wonder if anyone could kindly help me with? I'm really stuck on it at the moment.
What I'm trying to do is take one object and multiple it hundreds of times and have them cascade down the screen, so it looks like it fills the whole screen with multiples of this one object - from the bottom to the top of the screen.
Does that makes sense??
Is there an effect I can use to achieve this? I've had a look, but I'm a bit new to this and it's not jumping out at me.
Any help or ideas would be really appreciated!
Thanks so much
Joseph W. Bourke
Re: Filling the Screen
on Sep 1, 2013 at 4:00:19 pm
It sounds as if a particle system is what you want to use. There are a few which come with AE (Particle World, etc.), and the king of the hill, Particular.
I can't remember whether the included ones have the ability to pile up on an alpha channel, but that is what you want to do. Where the alpha ends at the bottom of the screen, is where you would want the particles to start accumulating. In Particular, you can even set them to bounce and settle. Here's some info on Particle Playground:
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Newton 2 also has that capability, with actual physics capabilities - gravity, weight, and a number of other factors, but it might be overkill, although I also think it might cost less than Particular.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
zoe griffiths
on Sep 2, 2013 at 5:47:10 am
Thanks Joe, really appreciate your help.
I used particular and it's created the sort of effect I was looking for. Still can't work out how I'd get them all to settle on the bottom of the screen, but they're spreading out to fill the screen, which will work for now.
Thanks again!
Zoƫ
mathew fuller
on Sep 1, 2013 at 6:20:31 pm
My parenting tutorial might cover what you are talking about.
http://library.creativecow.net/articles/fuller_mathew/AE-Parenting-Possibil...
My Work:
http://www.morecompletefx.com
Tudor "Ted" Jelescu
on Sep 1, 2013 at 7:16:51 pm
Depending on how you want the particles to animate you can use Plane Space from Red Giant also.
Another good option is to use one layer with the Generator from the Mettle plugins - either FreeForm Pro or ShapeShifter AE. You can create multiple instances and then animate them to fill the screen with a bit of tweaking.
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Sep 2, 2013 at 4:07:12 pm
Just curious: would AE's own Motion Tile work in a case like this?
Dave LaRonde
Former Sr. Promotion Producer
Tudor "Ted" Jelescu
on Sep 3, 2013 at 6:34:09 am
It could on a layer with alpha, but the animation of the image filling the screen would be pretty boring. However this opens up a new posibility: use Motion Tile to create a perfect grid from one layer and then Card Dance to animate the tiles.
Tudor "Ted" Jelescu
Senior VFX Artist
