What would be the best way to recreate something similar to this?
Jackson Redshaw
on Aug 31, 2013 at 5:27:31 pm
Hey,
I'm trying to put something together like this:
http://footage.shutterstock.com/clip-8703-stock-footage-searchlights-loop-e...
Except I'm going to have 4 lights, two on either side that cross over.
What would your suggestions be? I've tried a couple of ways using lights but just can't 'nail it'
Jackson Redshaw
http://www.youtube.com/MITLRproductions
John Cuevas
Re: What would be the best way to recreate something similar to this?
on Aug 31, 2013 at 7:36:19 pm
Create a white solid and make it a 3D layer. Add white lights and the bottom corners of your comp and place them 10 pixels in front of the white solid. Adjust the lights settings to match and animate rotation to taste. You could also adjust the material properties of the solid to make it shine more or less.
I made a sample project with 2 lights in CS5.5. 6463_spotlights.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jackson Redshaw
on Sep 5, 2013 at 4:30:27 am
Brilliant. Thanks!
I edited it a little to come up with the effect I wanted. Ill post a link to it shortly.
Jackson Redshaw
Jackson Redshaw
on Sep 5, 2013 at 8:21:40 am
Here's the final product.
As you can see I substituted the White Solid for a background I made of Fog, added in some 3D text, added in some subtle camera flashes and of course a red carpet!
This was for a film festival I helped run.
Jackson Redshaw
John Cuevas
on Sep 5, 2013 at 11:21:13 am
Looks good, glad I could help out...do I get a credit? LOL
Thinkck.com
Tudor "Ted" Jelescu
on Sep 1, 2013 at 12:44:25 pm
There's a few ways to go about this- John described a good one- here's a couple more:
you can animate masks with feathered edges on semitransparent white solids.
OR
Use AE lights with Trapcode Lux to make the light cone volumetric.
Tudor "Ted" Jelescu
Senior VFX Artist
