Motion blur colour outline
Henry Gaunt
on Aug 27, 2013 at 7:42:40 am
Evening all,
Due to the colours used (mandatory) I am getting a coloured outline on any motion blur in my project. You can see it here with the '6' compared to the '1' in the image below.
Is there a way, if any, of fixing this - or most likely in AE - using a trick to get around the issue?
Thank you,
Henry
Cassius Marques
Re: Motion blur colour outline
on Aug 27, 2013 at 2:39:31 pm
I seems right as it should to me. A magenta blurring over a cyan background should display as blueish.
You'll have to think that you should see things playing at the desired FPS, not frame by frame. Your eyes should perceive things the way they are suppose to.
If you want to avoid or reduce that, you'll have to color correct with adjustments on top of that.
Walter Soyka
on Aug 27, 2013 at 3:40:33 pm
Open your project settings (File > Project Settings, or Ctrl+Shift+Alt+K on a PC, Cmd+Shift+Opt+K on a Mac) and tick the box for "Blend Colors Using 1.0 Gamma."
This will change the math for blending colors and eliminate the dark fringing you're seeing on the motion blur.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Henry Gaunt
on Aug 28, 2013 at 2:47:27 am
Thank you Walter. That's exactly what I was after.
