Looping opacity across several shape layers
Mike Plenty
on Aug 24, 2013 at 7:06:41 am
I have a number of small, square shape layers positioned next to each other going across the screen, each set to around 50% opacity. I want a kind of 'pulsing' effect where a higher level of opacity will travel across these shape layers from left to right and then cycle round again.
Is there an easier and more flexible way to set this up other than manually keyframing the opacity on each layer and then offsetting them (maybe by using a different effect or expressions)? I want to be able to easily adjust the pace the opacity travels through the squares, add more square layers, and be able to extend the length of the animation without having to deal with an increasing number of keyframes.
John Cuevas
Re: Looping opacity across several shape layers
on Aug 24, 2013 at 12:50:16 pm
You could just create a luma matte precomp. If you use the loopOut("cycle") you would only need 2 keyframes, and if you want to change the timing, just adjust those and it would update automatically.
I made a quick example project.
6446_lumamatte.aep.zip
For more control of the pulses, you might want to try the expressions forum for a different approach to the problem.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Mike Plenty
on Aug 27, 2013 at 2:52:55 pm
Thanks! That makes sense.
I need to try and set it up so the squares light up one by one, and then fade back down to the original level - I've managed the first bit by using toggle hold keyframes on the position of the luma matte (not sure if that's the best way though) but can't figure out an easy way to fade them back down
