Animating a knot AE
David Amichai
Animating a knot AE
on Aug 23, 2013 at 8:27:55 pm
I'm trying to create an animation of a rope tying itself in AE.
Basically im using two shape layers. One a solid stroke (parent), the other a dashed stroke (child). I'm animating splines to loop the rope around itself and create a knot.
AE knot
Problem is since the dashed line is a single layer it intersects in such a way that it makes it very hard to clean up. Any ideas to make it look more like a knot and not a jumble
Any help on this would be much appreciated.
mathew fuller
Re: Animating a knot AE
on Aug 23, 2013 at 9:42:19 pm
1.Make both your original strokes slightly thinner
2.Duplicate your solid stroke, make it hard edged with a dark brown or black and place it under your other strokes.
3. Change the original strokes to feathered edges and it should look like it has a shadow along the edges, giving it the illusion of depth, and will help separate it visually from all the other brown rope when it becomes a knot.
Alternate idea... do a soft bevel on the alpha and maybe a little outer glow (dark color). You may have to precomp for this to look right.
My Work:
Tudor "Ted" Jelescu
on Aug 25, 2013 at 5:39:16 pm
Another way would be to do this 3D using Zaxwerks 3D Serpentine:
Tudor "Ted" Jelescu
Senior VFX Artist
© 2018 All Rights Reserved
