Foam effect in 3D space?
Matt Waryga
on Aug 15, 2013 at 2:45:06 pm
Is it possible to have the built in AE effect "foam" interact in 3D space, i.e. with a camera and some text?
I was surprised not to find this brought up already. Maybe I missed it.
-cheers
John Cuevas
Re: Foam effect in 3D space?
on Aug 15, 2013 at 2:59:49 pm
Foam doesn't have that capability. Both of the particle world effects can use a 3D camera, but don't have the ability to interact with 3D objects. Trapcode Particular can use obscuration layers(text) to make particles move in front or behind the layers.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Matt Waryga
on Aug 15, 2013 at 3:23:49 pm
tHANKS FOR YOUR RESPONSE. RENDERING AT THEM MOMENT HENCE THE CAPS. SORRY. ANYWAY i WAS MODIFYING THE DATE IN A PROJECT MY PREDECESSOR HAD CREATED USING THE FOAM AND i WANTED TO SPICE IT UP A LIL WITH 3D CAM ETC. CAN'T MOVE CAM WITH THE FOAM. THAT'S WHAT i WANTED TO ACCOMPLISH. COULD DEF DO OTHER PARTICLE GEN'S BUT I DON'T WANNA SPEND TOO MUCH TIME ON THE PROJECT.
tHANKS,
mATT
Walter Soyka
on Aug 15, 2013 at 8:08:33 pm
[Matt Waryga] "RENDERING AT THEM MOMENT HENCE THE CAPS. SORRY. "
You can close the comp viewer panel before starting a render.
Then you don't have to shout at everyone :)
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
John Cuevas
on Aug 15, 2013 at 8:43:26 pm
YOU CAN DO THAT???? I DIDN'T KNOW THAT!
Thinkck.com
