Time Remapping issue (missing frame?)
Phil Rad
on Aug 14, 2013 at 9:24:15 pm
I have created an animation that is 40f long and I want to loop it. I placed the animated Comp in my main Comp, added Time Remap with an expression of loopOut(type = "cycle", numKeyframes = 0)
I lengthened the animation out so it loops and it does it just fine but at every 40th frame, it disappears for one frame and loops again. I have no idea what is going on and it's driving me nuts.
Any idea?
Todd Kopriva
Re: Time Remapping issue (missing frame?)
on Aug 15, 2013 at 3:20:56 am
Show a screenshot of your composition, being especially careful to show your time remapping keyframes.
After Effects team blog
Phil Rad
on Aug 15, 2013 at 1:24:06 pm
Here's the sequence (character is blurred on purpose for this example).
38f:
39f:
40f (goes blank):
41f (starts the loop again):
Darby Edelen
on Aug 15, 2013 at 6:26:21 am
[Phil Rad] "I lengthened the animation out so it loops and it does it just fine but at every 40th frame, it disappears for one frame and loops again. I have no idea what is going on and it's driving me nuts."
Go to the last keyframe on the time-remapping property. Then go back one frame (a shortcut key for this is Page Up). Add a keyframe there then remove the last keyframe.
Make sure you do it in that order or it'll mess up the time-remapping good.
As far as I can recall this issue never occurred in older versions of AE but appeared sometime around CS4... or maybe that's just when I started noticing it :)
The last frame of a 40 frame composition is frame 39 (since the frames start from 0) but the time-remapping creates the last keyframe with a value of 40.
This behavior only causes problems with compositions as the last frame of a footage item (movie) is simply repeated once the time re-mapping moves beyond it.
To fully fix the loop you'll also need to copy the first time-remapping keyframe and paste it one frame in front of itself.
Gee, while I'm thinking about this maybe I should file this as a bug :)
Darby Edelen
Phil Rad
on Aug 15, 2013 at 1:25:07 pm
It's odd that I changed the expression to loopOut(type = "cycle", 0) and it seems as if issue went away???
Darby Edelen
on Aug 19, 2013 at 2:58:36 am
That is odd because that expression should evaluate to literally the exact same thing as your original expression :)
Darby Edelen
