Render with transparent background?
Thomas Holmegaard
on Aug 14, 2013 at 8:51:22 am
I've had a problem with rendering with the alpha channel. I do make sure that I have checked the box so there's no background and render it with RBG+Alpha quicktime.
When I then import it after it's rendered there's no background in After Effects. But the background still shows when I import it to other programs like Sony Vegas and Corel Video Studio Pro X4
How do I render it so it keeps the alpha channel no matter what program you export it too?
John Cuevas
Re: Render with transparent background?
on Aug 14, 2013 at 11:50:39 am
You may want to post in the other studios, but if you bring it back into AE and you have an alpha channel, the issue is that Vegas and Corel are interpreting the footage correctly. You many need to change the way you are importing into the programs to tell the software that there is an alpha channel and it needs to use it, that's how it is in Avid.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
