Manipulating motion blur
pawl fisher
on Aug 11, 2013 at 3:10:53 am
Is there a tutorial online somewhere on manipulating the motion blur in after effects?
for example, I've noticed on my keyframes when moving position the blur starts like 1 frame early, like there is a blur before you see a motion. is there a way to alter that? and also the amount of shutter etc...
Dave LaRonde
Re: Manipulating motion blur
on Aug 11, 2013 at 3:49:50 am
Don't worry about it. Just view it at the proper speed and things look fine.
Dave LaRonde
Former Sr. Promotion Producer
Todd Kopriva
on Aug 11, 2013 at 4:59:10 am
You can set the shutter phase to adjust this behavior. Information is in After Effects Help:
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
After Effects team blog
pawl fisher
on Aug 13, 2013 at 4:27:19 pm
I'm sorry I'm confused on what you mean. You mean the proper framerate?
"Don't worry about it. Just view it at the proper speed and things look fine.
Dave LaRonde
KCRG-TV (ABC) Cedar Rapids, IA"
mathew fuller
on Aug 13, 2013 at 4:45:03 pm
He's saying you won't notice the difference once it's rendered anyway..... Tell me if I'm wrong.
My Work:
http://www.morecompletefx.com
Todd Kopriva
on Aug 13, 2013 at 4:53:27 pm
Did you try what I suggested in my post, modifying the shutter phase?
Dave LaRonde
on Aug 13, 2013 at 8:10:59 pm
I'm saying that when you look at it in a RAM Preview -- previewed at the comp's frame rate, of course -- you won't see anything wrong. It should look just fine. If it doesn't, you have other problems going on.
Needless to say, if you don't see it in the RAM Preview, you won't see it in rendered file.
Dave LaRonde
mathew fuller
on Aug 11, 2013 at 7:09:54 am
You can alter motion blur samples per frame and set the shutter angle in the comp settings advanced tab.
Press ctrl K PC
Cmd K on mac
To get to comp settings.
My Work:
