keyframe problem
stig olsen
keyframe problem
on Aug 8, 2013 at 8:54:53 am
I have some elements that is supposed to move over the screen with a white background.
I have key framed the elements to move over the screen in different speed but somehow I see some "chopping" or what you call it. The movement is not as smooth as is should be. The keyframes are set to ease ease.
Stig
Dustin Lawhorn
Re: keyframe problem
on Aug 8, 2013 at 2:01:27 pm
Stig,
Just for clarification, are you seeing this problem on the Rendered file (final file) or during the RAM Preview or just in the Comp viewer?
-dl
stig olsen
on Aug 8, 2013 at 2:12:21 pm
Hi, both in the composer window, the monitor and the rendered output.
It is also some jittering / stuttering on the objects that move horisontally.
Stig
Dustin Lawhorn
on Aug 8, 2013 at 4:33:39 pm
Hmmm. It could be jutter? check out the thread here: http://forums.creativecow.net/thread/2/963872
-dl
