ERROR: Render Graph Stack Overflow -- Composition Too Complex (78 -- 6)
Rory Boen
on Aug 8, 2013 at 4:08:41 am
I am working on a pattern composition that includes a sub composition consisting of about 10 vector layers duplicated hundreds of times in a main composition and am running into this problem on AFX CS6:
Does anyone know if there is a way to bypass such an error by purchasing more RAM, etc? So far masking things before they get imported into AFX has been a difficult method of continuing the project; but it's not a true solution to the "sound barrier" I appear to of hit for the first time.
Roland R. Kahlenberg
Re: ERROR: Render Graph Stack Overflow -- Composition Too Complex (78 -- 6)
on Aug 8, 2013 at 4:47:00 am
There's some info here - http://myleniumerrors.com/2008/12/13/78-6/
I would look at pre-rendering the lower level pre-comp and look at ways to reduce RAM. This isn't part of the info in the link above but IT could be memory related.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
