Clipping highlight signal
thiery roussel
on Aug 8, 2013 at 1:07:10 am
.mov seem to have some clipping happening on import or export from after effects.
i'm getting proresHq clip out of premiere to blur some face, and then i export for the grading in resolve in proresHQ. In Premiere CC, i see those overbright (above 100ire), they are not clip. But this doesn't seem to pass on in after effetcs. I try with the original .MXF, no chance. I mess a lot with Color management. And same thing in CS6. So far, i drop my output white in 32bits to retain a maximum of signal for the colorist.
But this is not a viable solution.
I always thought i could import a .mov in after effects, then render in the same codec and obtain the same signal.
What have I missed?
thank you
