import 3D Spline
Marc Nibor
import 3D Spline
on Aug 6, 2013 at 8:40:47 am
I'd like to import a 3d Spline from 3DS Max and use it as a path to animate a particular emitter on it over time.
It's for a project that features the well known animated particular streaks... the problem so far is that all tutorials I found on this are based on somehow "random" paths generated from an expression.
I need the path to be a very specific in 3D.
I haven't figured out how to build a "real" 3D path in AE yet... in Max it would take me just a few minutes to create a really complex spline - but I don't know how to import it inside AE
What would be the best approach?
Joseph W. Bourke
Re: import 3D Spline
on Aug 6, 2013 at 9:34:21 am
Here's a script for Max which will do the job by way of the 3D camera:
http://www.scriptspot.com/3ds-max/scripts/after-effects-animated-position-e...
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Marc Nibor
on Aug 6, 2013 at 11:26:59 am
Thank you, this looks great! : )
Walter Soyka
on Aug 6, 2013 at 3:22:29 pm
[Marc Nibor] "I'd like to import a 3d Spline from 3DS Max and use it as a path to animate a particular emitter on it over time... I haven't figured out how to build a "real" 3D path in AE yet."
Here's an all-Ae solution:
Add a light to your scene and name it Emitter 1. Tap the P key to reveal its position properties, then right-click the word Position and choose "Separate dimensions." You can now animate X, Y and Z independently.
With Particular, choose "Light(s)" as the emitter type. You can use the light's intensity to modify the emitter's particles per second if you like, or you can turn the "Particles/sec modifier" to "None" to use the standard Particular controls.
You can turn the visibility of your Emitter 1 light layer off if you don't want it to light your scene. Particular will still track it.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
