Jerky slow motion footage with twixtor using 720/50fps footage
Seb Steward
on Aug 4, 2013 at 8:00:57 pm
Hi i have checked the forums but not found anything specifically relating to my problem
I have filmed a test video to demonstrate the jerky and laggy footage Im getting from twixtor when attempting to slow a piece of footage down to around 5% of original speed. I have seen many other uses of twixtor shot with a gh2 on 720/50fps like mine that look smooth and great so it must be possible somehow.
Here is an example of what happens:
I have my composition set to 50fps and the footage is 50fps. Twixtor input frame rate is also set to 50fps.
The gh2 outputs .mts files and I use Handbrake to convert them to mp4 so they are compatible with AE.
I have checked each part of my workflow and cant seem to figure why i'm getting these results.
Any help much appreciated!
