Scale after effects project like a vector?
Jeremy Arimado
on Aug 4, 2013 at 4:16:23 pm
I was wondering how i would be able to scale my 720p comp to 1080p without losing any quality.
It's just vector layers so i think this should be possible.
Cheers,
Jeremy
Dave LaRonde
Re: Scale after effects project like a vector?
on Aug 5, 2013 at 1:39:22 am
Use the Continuously Rasterize switces. Should work fine.
Dave LaRonde
Former Sr. Promotion Producer
Emmanuel Jimenez
on Aug 5, 2013 at 5:28:37 pm
You shouldn't have any problem as long as you continuously rasterize. You should do some research on that little button, it does alot more than keep vectors crisp.
I rock.
Erik Waluska
on Aug 5, 2013 at 9:43:55 pm
Once you set the continuously rasterize switches for your layers you can use the Scale Composition script. Go to File>Scripts>Scale Composition and then enter the new comp dimensions or scale factor, which in your case would be 1.5.
Erik Waluska
EAWmedia
