Masking an Effect
Evan Thompson
Masking an Effect
on Aug 3, 2013 at 12:48:27 pm
Hello,
Question:
How do I use a mask to mask the effect on a layer and not the layer itself? For example, I want to have a blur effect pass over a text layer, but I don't want it effecting the entire layer all at the same time.
Is this done by using expression controls? If so, how?
-Evan
Todd Kopriva
Re: Masking an Effect
on Aug 3, 2013 at 3:26:09 pm
There are many ways. One is to put a mask on an adjustment layer and also apply the effect to the adjustment layer.
These two videos show a couple of approaches:
http://tv.adobe.com/watch/learn-by-video/adobe-after-effects-cs5-motion-tra...
http://www.peachpit.com/podcasts/episode.aspx?e=eb0dc392-6e0c-4028-817d-cec...
After Effects team blog
Evan Thompson
on Aug 3, 2013 at 4:53:52 pm
An adjustment layer! I don't know why I didn't think of that. I guess I was thinking on a different track.
That should do the trick.
Thank you!
-Evan
Evan Thompson
on Aug 4, 2013 at 12:01:36 am
And another quick question to go with that.
What is the proper way to have the adjustment layer effect only select layers instead of everything below it? I know I can create a different sequence for just the layers I want effected, but is there a better way to do that?
-Evan
Todd Kopriva
on Aug 4, 2013 at 12:30:06 am
That's not possible. That's not how adjustment layers work. An adjustment layer applies to the composite of the layers beneath it.
If you want to apply an effect to a specified set of layers, you have many options. Here are three:
- Precompose the layers and apply the effect to the precomposition layer.
- Precompose the layers and add an adjustment layer within the nested composition.
- Apply the effect to each of the layers individually.
Evan Thompson
on Aug 4, 2013 at 1:02:36 am
Alright, I can work with that. That's as far as I knew about adjustment layers. I thought that maybe they could be applied to specific layers like in Photoshop.
Thank you for your help and information. I appreciate it.
-Evan
