Cineware / Cinema 4D light After Effects CS6 (non cloud)
David Chaudoir
on Jul 31, 2013 at 12:23:50 pm
Hi All
I am working at an ad agency that has C4R14 and AE CS6 - am I able to utilise the new link between the 2 programmes I have put the format and exchange plugins from C4D into AE but not sure if I need to do anything else... I only woke up to the link up between C4D and AE last week and want to see if I can set it up here.
Any help / advice gratefully received.
John Cuevas
Re: Cineware / Cinema 4D light After Effects CS6 (non cloud)
on Jul 31, 2013 at 12:37:44 pm
You still have to render out of C4D and when you set that up, on the save tab, open up the "Compositing Project File" pulldown. FRom there I check everything.
Rob Garrot at Lynda.com has some really good tutorials on the workflow between C4D and AE, you could probably pick up a one month subscription and really learn the ins and outs.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
siva kumar
on Oct 3, 2013 at 9:33:02 am
Sir i am using c4d studio r14 and after effects cc.but cineware can't work.means 3d live pipeline not working.
