curved directional blur?
Tom Masters
on Jul 26, 2013 at 10:14:25 pm
wondering if there is any way to do this:
A directional blur, that follows a defined path, like a curve or a spline.
could be handy for smoothing out imperfections on curved surfaces, or hair.
Darby Edelen
Re: curved directional blur?
on Jul 26, 2013 at 10:47:09 pm
Blur & Sharpen > CC Vector Blur does this but you'll need a way to define the curve. You might, for example, create a white/black matte. The transition between white/black would be the "line" along which CC Vector Blur will blur. Use this matte as the Vector Map for the effect. I believe you'll also need to rotate the Blur 90° if you use the Natural mode.
Tweak the Ridge Smoothness and Map Softness as well as the Strength to adjust to your needs.
Darby Edelen
© 2018 All Rights Reserved
