Preserving Green Color in front of Chroma Screen
Yunoo Jong
on Jul 9, 2013 at 2:59:03 am
I'm novice and this is my first post here.
I would appreciate any advice.
I did a horrible thing. The only thing you shouldn't do in front of a green screen.
I brought green into frame. I thought that since it's technically surrounded by flesh colors and off-white in the mid-ground, I thought there might be some way.
25second clip here
http://www.youtube.com/watch?v=zSycFQAZgZ4
Is there any way on God's green earth to preserve the green (via color changer, leave color, some sort of matte(?)--other than masking each blade of grass)
Many thanks to anyone who could offer advice.
Cheers,
Yunoo
Frank Feijen
Re: Preserving Green Color in front of Chroma Screen
on Jul 9, 2013 at 9:09:53 pm
Other than a reshoot?....
I'd try to do the reverse: key out the grass as good as you can without touching the background. Since the background isn't a uniform green, you might have to use masks to specify different keys to different regions of background. And after that: start choking and refining. I think i would use the color range-keyer...
Yunoo Jong
on Jul 10, 2013 at 6:19:08 am
Wow... That's just brilliant. Thank you so much!
--Back to work.
Frank Feijen
on Jul 9, 2013 at 9:23:06 pm
