How to add textures to TEXT in AE 6?
Richard Garabedain
on Jul 8, 2013 at 8:26:52 pm
I had thought there was a way to add materials to text in AE 6. I see material options under the text, but i do not see a place to actually add the material. I feel stupid...
Dave LaRonde
Re: How to add textures to TEXT in AE 6?
on Jul 8, 2013 at 9:18:13 pm
Use the text layer as a track matte for the desired texture layer.
Dave LaRonde
Former Sr. Promotion Producer
Todd Kopriva
on Jul 9, 2013 at 12:03:09 am
If you're trying to add an image layer as a texture for the face of a 3D object, you can't do that.
See these resources for what the material options properties are for:
http://blogs.adobe.com/aftereffects/2012/05/free-3d-material-options-projec...
After Effects team blog
Isaac Borjas
on Jul 9, 2013 at 6:09:05 pm
Or if you want your Text to look 3D'ish with the Texture you Want use the " Shatter Effect " on the Texture Layer you want to use and change the follow settings :
Under Shape
Patter = Custom;
Custom Shatter Map = Your Text Layer;
Under Both Force (1 & 2)
Force = 0;
Radius = 0;
Strenght = 0;
and that pretty much it, you can play with the " Extrusion Path " for more 3D look there is some limitations to this so keep that on mind.
