After Effects C4d Cineware Camera Morph
field walsh
on Jul 3, 2013 at 7:11:28 pm
Anyone able to extract Scene Data using a Camera Morph tag and have it work ok? When I use the camera morph tag the camera does not import correctly, it is only using the last camera in the morph sequence. Other cameras are working fine, but it would be nice to use camera morph in cineware.
Ashish Gupta
Re: After Effects C4d Cineware Camera Morph
on Jul 6, 2013 at 11:40:41 am
field,
I don't think AE can work with camera morph tag...
You can bake the camera morph to keyframes using the Bake objects command
Timeline - Functions - Bake objects
Than import that keyframed camera to AE..
Ashish Gupta
Motiongraphics artist and 3d generalist
aashi.29nov@gmail.com
Jason Schwarz
on Dec 16, 2014 at 9:16:32 pm
Works here.
In the Timeline:
1. If you have View>Show>”Show Animated” enabled… Disable it. This will show the camera object in the timeline.
2. In the Timeline, Select the “Morph Camera” Object… Not the “Morph Camera” Tag (Which has the animated Blend).
3. Select Functions>Bake Objects… Bake.
4. Import C4D file into AE, Add to scene, Hit “Extract” in Cineware.
5. Done
Jeffrey LeJune
on Jan 25, 2015 at 12:31:29 am
This is kind of working for me. I'm morphing between two cameras but each camera has a different "focus distance" parameter. In the bake dialog box I have the parameter checkbox checked but the baked camera only has the "focus distance" of the second camera and no keyframes for that parameter. Can't find anything in the help files for the bake objects function that explains what the parameter checkbox is suppose to do.
Jeffrey LeJune
on Jan 25, 2015 at 12:58:14 am
Found the answer on how to bake properties of the morph camera here http://monoplex.tumblr.com/ look for his blog post about "Baking Camera Morph"
Right Click the “Morph Camera” (in the timeline - not the tag) and choose “Add Property Tracks” and add Focal Length and Focal Distance. In the bake function you need the parameter check box checked.
