Pasting Mocha Masks in AE - Error
Ben Woody
on Jul 2, 2013 at 4:27:26 pm
When attempting to paste a hand full of masks that I have created in Mocha V3 into AE, many of my masks are completely deformed and incorrect. I have screen shots available to further explain this bug. Has any one encountered this before? I am not sure how to get around it.
Ben Woody
Re: Pasting Mocha Masks in AE - Error
on Jul 2, 2013 at 6:22:12 pm
Original masks in Mocha:
Distorted splines in AE:
Roland R. Kahlenberg
on Jul 3, 2013 at 1:55:40 am
That looks freaky. Have you tried pasting as mochaShapes rather than masks? You should get the folks at Imaginner Systems have a look at this - http://forum.imagineersystems.com/forumdisplay.php?f=55.
Good luck
- RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
Ben Woody
on Jul 3, 2013 at 2:34:31 pm
I am not sure how mocha shapes work, I have never used that feature before. What is the difference?
on Jul 3, 2013 at 6:03:37 pm
The mochaShape effect creates mattes. The down side is that you can't tweak the edges like you can with a mask.
To paste mocha spline date, you copy/export from mocha and simply CTRL+V onto a selected white solid (for use as a matte) or directly onto the backing plate.
HTH
RoRK
Ross Shain
on Jul 8, 2013 at 3:18:05 pm
It is possibly that the tracking related to the mask was doing something strange. If you look at the surface in mocha and see the corners crossing, this could be the issue.
If you ever see issues like this, it is best to contact the mocha support team direct: http://www.imagineersystems.com/contact_form
Best,
Ross
Ross Shain
Imagineer Systems
Marcin Foszczka
on Jun 28, 2017 at 2:21:27 pm
I know the post is old, but I have the same issue and I would like to know if did You solve the problem?
