After Effects: Video not playing in composition window
Arjun Sood
on Jun 28, 2013 at 4:10:39 pm
I'm new to AE, and i'm facing an issue.
When previewing any clip, the window just stays blank, while the time is still running. Please see the attached screenshots.
http://imageshack.us/photo/my-images/542/obv4.jpg/
http://imageshack.us/photo/my-images/600/apan.jpg/
Version: After Effects CC 12.0.0.404
System info:
Windows 8 (64-bit)
Intel Core i5 @ 2.5Ghz
4GB RAM
Nvidia GeForce GT 630M
Is it some video card problem, compatibility issue, or something else?
Tried searching a lot, but couldn't find anything.
Thanks a ton :)
John Cuevas
Re: After Effects: Video not playing in composition window
on Jun 28, 2013 at 4:47:57 pm
You are in the footage window, not the comp window. Go into the comp window and press "0" on the number keypad to start a RAM preview.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Arjun Sood
on Jun 28, 2013 at 6:29:10 pm
Hi John,
Thanks for the prompt reply.
I tried running it on the composition window with an AE template as well, still facing the same problem.
Have a look at the screenshot:
http://imageshack.us/photo/my-images/541/dmx3.jpg/
Arjun
John Cuevas
on Jun 28, 2013 at 6:57:32 pm
And you are pressing "0" on the number keypad to start a RAM preview, which renders and caches each frame to RAM?
Thinkck.com
Arjun Sood
on Jun 28, 2013 at 8:00:24 pm
Yep, tried that.
Here's the screenshot:
http://imageshack.us/photo/my-images/189/89fs.jpg/
Regards,
Arjun
John Cuevas
on Jun 28, 2013 at 8:37:48 pm
Are you trying to play that video off an external hard-drive?
Thinkck.com
Arjun Sood
on Jun 28, 2013 at 8:43:14 pm
Nope.
C:UsersDownloadsAE Templatestemplate_namefilename.aep
Regards,
Arjun
John Cuevas
on Jun 28, 2013 at 9:15:56 pm
So you are using a template, when you have everything paused, is your comp window correct?
Thinkck.com
Arjun Sood
on Jun 29, 2013 at 12:15:25 am
I'f i understood u right, no i don't see a still video even when paused.
Here's a screenshot of the template loaded without playing a preview:
http://imageshack.us/photo/my-images/199/1a9q.jpg/
Regards,
Arjun
Jake Camboia
on Aug 29, 2014 at 5:51:37 pm
I'm having the same problem. "0" does not work. Any other suggestions?
Nqobizitha Mlilo
on Jun 30, 2013 at 1:12:20 am
Hi there!
I have the same problem! my composition window is justb blank!
I have an nVidia GTX 670m running on a toshiba Qosmio x870 with 16GB ram. I have 2 cards on the same system though, an intel and the nVidia GPU if that info helps!???
