default project settings
anders bundgaard
on Jun 26, 2013 at 9:32:21 pm
hello all,
is it possible to change the default project settings so when i make a new project it will always be, for example, 32bit with a srgb profile?
thanks in advance
anders
Todd Kopriva
Re: default project settings
on Jun 26, 2013 at 9:50:01 pm
Create a template project.
After Effects team blog
anders bundgaard
on Jun 26, 2013 at 9:52:24 pm
project template as in using that everytime i need a new project or is there a way of making it the default settings when i make a new project?
Todd Kopriva
on Jun 26, 2013 at 9:58:15 pm
Make a template project that has the settings that you need. Open that each time you need to start a new project. Be sure to read the page that I linked to so that you understand what a template project is.
anders bundgaard
on Jun 26, 2013 at 10:00:44 pm
thanks.
John Cuevas
on Jun 27, 2013 at 12:01:02 am
Load Project or Template at Startup
Will launch a project or template every time your start After Effects. For example, if you have a certain folder/file structure you like to keep for your AE projects, you can setup a virgin project the way you like it and save it as a template by giving it a .aet extension. Now every time you launch AE your custom setup will be automatically loaded.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
