JPEG sequences
Marc Lucas
JPEG sequences
on Jun 26, 2013 at 3:07:51 pm
Imported a JPEG sequence and got the footage in the AE timeline. Went to do a ram previous of the timelapse and I get a warning saying RAM preview needs 2 or more frames for playback.
William Scholik
Re: JPEG sequences
on Jun 26, 2013 at 4:51:26 pm
Without seeing your comp I can't know for sure. My best guess would be that your work area is shorter that 2 frames. Go to the pont in your timeline that you want the preview to start and press "b" then go to the point where you want it to end and press "n". This will set your in and out points. If this was your issue the it will fix your problem.
“We cannot solve our problems with the same thinking we used when we created them.”
― Albert Einstein
chris brett
Re: JPEG sequences
on Jun 26, 2013 at 4:58:15 pm
-- Hi --
.......oprobably this - check the markers that determine the section of timeline yu are working on --- they look like yellow cushions on the grey bar along the top --
---------------------- chris ---
Cassius Marques
Re: JPEG sequences
on Jun 26, 2013 at 4:54:24 pm
Those errors are usualy related to memory issues. Check your footage dimensions, try purging all memory and restart after effects/computer as a last resort.
Todd Kopriva
Re: JPEG sequences
on Jun 26, 2013 at 11:24:43 pm
What version are you using? 11.0.0? 11.0.2? 12.0?
After Effects team blog
Marc Lucas
Re: JPEG sequences
on Jun 26, 2013 at 11:29:32 pm
Hi Todd
CC
Was there any news on http://forums.creativecow.net/readpost/2/1038663
Kind Regards,
Marc
