Exporting full video using a Preset
Remi Belcourt
on Jun 22, 2013 at 1:50:03 pm
Hello for the first time, CreativeCow friends:
I found a preset on youtube, which I am trying to apply on a 3 minute music video:
It's a VHS effect, and it is perfection. The only problem, I suppose, is my RAM.
When I import the full music video into the preset project, the work area becomes just 15 seconds.
That doesn't surprise me, as my RAM is 8gb.
I am fine with working the small portion, so long as I can export the full portion.
So, can AE CS6 render the entire 3 minutes despite the 15 second work area?
I would like to know if this is even possible. I will take in any advice I can get.
Also I am open to look into other alternatives that attain this VHS look.
Thank you much,
Remi Belcourt
Roland R. Kahlenberg
Re: Exporting full video using a Preset
on Jun 22, 2013 at 5:34:24 pm
The Work Area is critical for certain preview options. It is used as the default in/out points stipulated in the Render Queue's Output Options. You can safely override the default in/out points.
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
Remi Belcourt
on Jun 23, 2013 at 1:54:30 am
This is excellent! This gives hope once more.
I will try when I am off work. Although if I have trouble, I may return to this thread. It is great for professional answers (as I am a novice in AE)!
Thank you much for the answer RoRk.
Remi Belcourt.
© 2018 All Rights Reserved
