Inconsistent audio drift FCP/Soundtrack Pro
Ian Mantgani
on Jun 18, 2013 at 5:11:58 pm
Hi folks,
I know audio drift issues are common between FCP and Soundtrack due to XML data, but I have no idea if that's what is causing my issue.
I export to Soundtrack Pro, add filters, and send back to FCP. Most of my clips work fine. Then, after a certain point in my timeline, anything that comes back from Soundtrack Pro is out of sync. I'm doing the same thing with those clips that I was doing with my other clips! Have checked that frame rates, sampling rates and bitrates are the same on both my FCP sequence and my Soundtrack preferences. What else can I do?
Thanks.
Walter Soyka
Re: Inconsistent audio drift FCP/Soundtrack Pro
on Jun 19, 2013 at 3:27:14 am
[Ian Mantgani] "I export to Soundtrack Pro, add filters, and send back to FCP. Most of my clips work fine. Then, after a certain point in my timeline, anything that comes back from Soundtrack Pro is out of sync."
Ian, you posted this question in the After Effects forum. I'd try the Final Cut Pro forum [link] instead.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
