After effects Particular
Sahil Zafar
on Jun 18, 2013 at 4:27:35 pm
Hi!
I am making this scene where leaves from trees will start falling, and fly in the air. And all of the leaves would get puzzled into a human (wizard). I reallllly want to know how to get the leaves in Particular to form a leave human, and then the leaves would disappear and only the real person will be standing. PLEASE HELP!!
Walter Soyka
Re: After effects Particular
on Jun 19, 2013 at 3:29:55 am
Effects like this are typically done with a layer emitter, and you do them backwards (starting with the final position, the human form), then time-reverse the layer.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Sahil Zafar
on Jun 19, 2013 at 1:10:11 pm
Thanks!!! But i don't think i got the reverse part... Bu thanks anyway!
John Cuevas
on Jun 22, 2013 at 3:52:37 pm
First you would create your animation using an alpha channel of the wizard as a emitter. The particles would emit off of him and up to the tree. Then you would take that entire effect, precomp it and use Layer>Time>Time Reverse Layer. To get them to fall from the sky/tree. For more control I would suggest using Time Remap, but that's a little bit more advanced.
Time-stretching and time-remapping
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Sahil Zafar
on Jun 24, 2013 at 9:28:51 pm
Got it. But as you might have guessed i am no expert in this, and when i use try to emit the wizard by making a mask, it starts emitting all over the place. I only want particles from the wizard.
Walter Soyka
on Jun 24, 2013 at 10:05:49 pm
[Sahil Zafar] "when i use try to emit the wizard by making a mask, it starts emitting all over the place. I only want particles from the wizard."
Effects see the entire layer, not the masked portion.
Precomp the wizard and mask him inside the precomp. This way, the layer that Particular sees has alpha, not masks.
Walter Soyka
Sahil Zafar
on Jun 25, 2013 at 7:37:34 am
THANKS!! i GOT it now.
Sahil Zafar
on Jun 25, 2013 at 10:59:46 am
Ok i have now tried making a mask around the wizard and then i pre-composed it, but even then when i added the particular to the solid layer above, there was still colorful particles coming from the black part.
