Limit number of lights layer in a composition
Grégory Villien
on Jun 17, 2013 at 12:13:06 pm
Hi, I need your help on my problem, I didn't found an answer on google (the first time !!!)
So, I work with Element 3D on a 3D projection mapping architecture. I want play with some lights movement for an impressive result in projection.
But.... After Effects don't want show more than 8 light layer on my architecture... when I add another light layer, one another will shut off... etc etc
I search in my preferences if I can found an option to fix that, in the preference of my comp also, but nothing.
I hope you have an solution for my problem
thanks ;)
Todd Kopriva
Re: Limit number of lights layer in a composition
on Jun 17, 2013 at 2:37:41 pm
That's a limitation of Element 3D, not of After Effects.
After Effects team blog
